cam swap. help w/V. springs
Old Nov 7, 2004 | 04:26 PM
blown94's Avatar
Im swapping to a cc305 cam with 1.5 RR's but I may go with 1.6's down the road. Im wondering what you guys would suggest as far as selecting a valve spring kit that would fit on stock heads. The RR's are crane gold 1.5's that i have now but i may swap out to 1.6's later when i add my powerdyne kit. Any suggestions with pro's and con's? Thanks
Old Nov 7, 2004 | 04:34 PM
97Z-pimp's Avatar
Re: cam swap. help w/V. springs
The combination motorsports EX-612's are good to 600 lift and fit stock heads.
Old Nov 7, 2004 | 05:16 PM
LWillmann's Avatar
The Crane 10308-1 kit is a double coil spring, and fit the stock heads with no machining. They're also good to .600 lift.
THe EX-612's are single coils, I believe.
Old Nov 7, 2004 | 07:44 PM
truedualws6's Avatar
You can also go with the Comp beehive springs. If you you decide on the
beehive route send me a PM and I'll give you all the part #'s.
Old Nov 7, 2004 | 09:20 PM
dmoor88's Avatar
beehive springs fit stock seats?
Old Nov 7, 2004 | 10:15 PM
blown94's Avatar
What about lifters? Can I stick with the stockers or should I get some Comps?
Old Nov 7, 2004 | 11:01 PM
dmoor88's Avatar
you should be able to reuse your stock lifters with a small lift cam like the 305, but just double check and make sure they look all right.
Old Nov 8, 2004 | 12:13 AM
T/A#4's Avatar
I went with the "BeeHive" springs. They will fit the LT1 or 4 heads without machining. You will need locators to corretly seat the springs. Just call Comb. Motor Sports & they will set you up. The BeeHives are the hot setup & will rev to the moon
Old Nov 8, 2004 | 01:03 AM
dmoor88's Avatar
what sort of lift can the beehive springs see?
Old Nov 8, 2004 | 10:07 PM
The 26915 beehive springs coil bind at 1.085" so depending on your installed
height you can handle .600" lift. If you install at 1.75" and include a safety
factor of .050" the spring can handle .615" lift. Here is more info from Comp:
Spring: 26915
Installed Load: 105 lbs@1.800"
Open Load: 293 lbs@1.200"
Spring Rate: 313 lbs/in
Coil Bind Ht: 1.085"
Outside Dia: 1.290"/1.060”
Inside Dia: .885"/.656”
Edited to add that you need to check retainer to oil seal clearance if you
are over about .580" lift.
carl.froehlich
Mar 13, 2015 12:38 AM
jj_burchiel
Mar 5, 2015 07:05 AM
InfernalVortex
Jan 17, 2015 09:35 AM
donot_4get
Sep 14, 2002 08:03 AM
