cam spec Q's
Old Apr 25, 2012 | 10:18 AM
77amc's Avatar
cam spec Q's
I've spent over a half hour google'ing and reading goofy posts and even got on GM's site that I typed in the #'s and NOTHING came up..
I have two cams.
--Cam 1= 241 cpc bc 1 ---Supposed to be a LT1 cam but would like to know the ACTUAL specs, and not "DUDE.. That's the same one I got!!!" or "Yup, It's aLT1 cam alright..."
--Cam 2=(at the back of the cam, by the plug) HOW IT'S ACTUALLY STAMPED!
1264
2 00
6143
(UNDER the two breather holes)
F 4
Thank you for your time.
E
Old Apr 25, 2012 | 12:16 PM
96capricemgr's Avatar
Re: cam spec Q's
Best guess I can offer is sometimes a pair of 4 digit numbers like you say is on the second cam can be lobe numbers. I can tell you searching Comp's 2010 catalog neither of those is a Comp lobe number though.
I don't know if that can help or not, at least now you have some idea of what numbers could mean.
Can you post pics? Not that I think anyone can visually identify cam specs but maybe the way something is stamped or etched could be familiar to someone.
Old Apr 26, 2012 | 12:44 PM
77amc's Avatar
Re: cam spec Q's
It is a GM Performance LT4 and having a custom grind done to it..
He put it on his "cam doctor" and checked it against GM's catalog.
Thanks Anywho.
E
DirtyDaveW
Mar 15, 2015 07:01 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
pimpss96
Feb 12, 2015 01:28 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Nov 20, 2014 06:03 PM
