Cam size ?'s
Old Jan 24, 2004 | 06:39 PM
BradJ's Avatar
Cam size ?'s
I bought a car with TPIS/AFR heads ( http://tpis.com/ ) They are part #500-526, under TPIS catalog, engine components, then air flow research heads. My question is what cam would be a good combo with these heads? Looking for something that is good for the street but make good use of the heads, I am not scared of a little aggressivness! Thank you for any of your thoughts!
Brad J.
Old Jan 24, 2004 | 07:00 PM
Spinner's Avatar
Something along the lines of 230/236, .550+ lift. Those head flow pretty decent, a hair better then stock LT4 heads. You'd see more potential with them ported.
Old Jan 24, 2004 | 07:03 PM
Red_94Formula's Avatar
The CC306 by compcams would be great. There are a lot of cams out there with around the same specs of the cc306 would be great as well. Just make sure you get a 112 lobe seperation. this should give you an idea of what numbers to look for in a cam. CC306 is a aggresive cam but streetable.
Old Jan 24, 2004 | 08:29 PM
LT4Z's Avatar
I would go with Comp cams XE 230/236 it makes goood power.
Old Jan 24, 2004 | 08:35 PM
AsianSensation's Avatar
I'm running the hotcam with AFR LT4 heads. But may be too mild for your taste.
Old Jan 24, 2004 | 08:47 PM
BradJ's Avatar
Really appreciate the suggestions! I was thinking about the CC306, but wasn't sure if that was to much cam? Thanks!
Brad J.
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
1775.Z28
Jan 11, 2015 10:51 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
