cam selection help.
Old May 23, 2012 | 09:00 PM
mikemassi's Avatar
cam selection help.
well the notorious opti went bad for the third time in 120,000 miles. my money situation is a little tight for heads, but i wanna put a cam in my car while doing the opti... what are some cams u can run with stock heads, i have 1.6 roller rockers but stock springs. car is an a4 with stock convertor beacuse my stall just blew up
i was reading about the CC503 and that apperently is good with stock heads? is there any others i can check out?
Old May 23, 2012 | 09:38 PM
6SpdLT1Z's Avatar
Re: cam selection help.
Definitely get new springs. Don't buy until you've decided on the cam, but the stock springs are barely good enough for the stock cam/1.5 rockers.
Bunch of good choices out there: CC503, GM856, Hotcam, Crane 227.
You'll also want to get another stall, especially if you are stock gears.
Old May 24, 2012 | 12:41 PM
Orr89rocz's Avatar
Depends on what you want the car to do? Little more power than stock with mild lobes for high spring life for daily driver or weekend warrior trying to get the most power possible out of the stock heads with no concern for spring life?
Various cams for various applications exist.
503 is a popular shelf grind that is about the biggest you generally want to go on stock heads. Has a good bit of lope to it but driveable. Not a bad cam really. 330-340whp is common with 6spd cars and bolt ons/tune. Has decent spring life too since the lobes arent super crazy and lift is somewhat moderate/mild. Nice small diameter double spring would fit the bill or possibly the PAC beehives but I like double springs over beehives
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jan 23, 2015 01:13 PM
Dec 17, 2014 11:00 AM
