Cam Seal area of cover damaged
Old Aug 24, 2008 | 12:36 PM
DSM PImp's Avatar
When removing the seal I grabbed the lip of the cover on accident and chipped it. Does the seal, seal against the side where its red or at the lip? Either way, do you think it will compromise the seal effect and I should get a new cover?
If you look at the pic (sorry that its not that great) you will see that only he small lip is damaged and not the side wall area.
Old Aug 24, 2008 | 02:15 PM
From what I can barely see, you might be ok.
Old Aug 24, 2008 | 03:01 PM
wrd1972's Avatar
I think your fine too.
Old Aug 24, 2008 | 06:18 PM
DSM PImp's Avatar
Coo thanks
Old Aug 24, 2008 | 09:57 PM
mzgp5x's Avatar
I did something similar to the lower hub seal. Used a dremmel to radius the crack so it would not propagate further. I have been running the same front LT1 (97) cover for 6 years with no further failures or leaks.
HectorM52
Jul 30, 2017 11:46 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
Queens94z28
Dec 20, 2014 09:11 PM
squarehead
Nov 21, 2014 08:02 PM
