Still hard starting with new pump and fpr
Old Aug 22, 2008 | 09:55 PM
pyro719's Avatar
Well I changed my fuel pump, brand new walbro 255 and a new fuel pressure regulator. I have 41 psi primed and it dosnt bleed off for about a half hour. Anything else i can replace to get this thing to fire up faster?
Old Aug 22, 2008 | 09:57 PM
What brand is the AFPR?
Have you checked the coolant temp sensor, to be sure its telling the PCM the correct engine temperature when you are trying to start it?
Old Aug 23, 2008 | 09:41 AM
pyro719's Avatar
Its not adjustable, its an auto zone replacement . I have a new coolant temp sensor I'll throw that in today and see what happens. Ever since I got my computer tuned by pcmforless my idle has been lower too?
Old Aug 23, 2008 | 11:26 PM
pyro719's Avatar
Put the new coolant temp sensor in and its still hard start? Maybe I just need a rebuild? It does have 145,000 miles on it now and about 30 bottle of nitrous through it.
Old Aug 24, 2008 | 06:38 AM
It is just a case of taking a few extra cranks of the engine to start it?
Old Aug 24, 2008 | 10:10 AM
pyro719's Avatar
exactly. It used to fire up with just a bump of the key, now it needs to turn over probly 5 times
Old Aug 24, 2008 | 10:29 PM
Does it start faster if you hold the accel pedal on the floor when you crank it?
What is the dash volt meter showing when the starter is cranking?
Old Aug 24, 2008 | 11:48 PM
lt1stroker's Avatar
im having the same problem. when i crank the car and accel it starts a little faster. Should i get a new fuel pump and FPR too? not trying to thread jack btw.
HectorM52
Jul 30, 2017 11:46 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
