Cam recommendations for 396 solid roller?
Old Mar 30, 2003 | 03:47 PM
BrianZ28's Avatar
I have a 396 solid roller, had it dynoed last week. Made 420hp & 379fpt. The numbers do not impress me, should I go bigger on the cam, Iam also running AFR 210cc heads straight out of the box. Don't know where the torque has gone to, thinking of going to a bigger cam, and have the heads reported. The current cam #'s are 242in. 254ex. 620lift.
Old Mar 31, 2003 | 12:02 AM
cef97ws6's Avatar
Brian got a few questions for ya. What version of the AFR 210's do you have? Fully CNC'd or partial CNC'd, What size combustion chamber did you get and what was your final compression ratio for the engine? Also do you have full length headers? The Comp Cams PN 12-772-8 is my pic with those heads and street use. It is 248-254 @.050 and .614 - .621 lift with 1.6 rockers. Should make around 520-540 fhp with the fully CNC'd 210's and around 11 to 1 Compression thru longtubes and exhaust. I think you could definately benefit by having some more intake duration. That is the best I can do without knowing more about your combination and how you are using it. Street or Race or Both. Hope that helps a little.
Old Mar 31, 2003 | 12:07 AM
96z's Avatar
96z
You need to get some head work done most likely. AFR's out of the box arent all that impressive. Id keep the cam for now and see how much more the head work will help...
oldschool
Feb 9, 2016 09:21 PM
alliance12364
Mar 6, 2015 04:39 PM
cmyname1
Feb 19, 2015 08:38 PM
95chwagon
Jan 13, 2015 09:19 PM
Wicked
Jul 25, 2002 04:19 PM
