Cam recommendation
Old Mar 6, 2006 | 08:11 AM
aboatguy's Avatar
Cam recommendation
My car weighs about 3600lbs with fuel and driver. I want a streetable cam that has power off of the line, but makes good power to about 6200.
I have a
58mm TB
Electric H20 pump
7/16 1.6 ratio NSA Comp Pro Mag rocker arms
1 3/4" primary Long tubes
3" collectors and 3" high flow cats
Smallest size pipe in my exhaust is 2 1/2" most of it is 2 3/4"
2800 stall converter with lockup
4L60E
3.45 rear end gears
285/40/17 tires
Here are my approximate flow numbers:
Valve life .100 .200 .300 .400 .500 .600 .700
Intake 70 146 202 244 269 275 273
Exhaust 60 116 153 172 187 193 196
What is your suggestion for a cam IE what cam would you run?
Old Mar 6, 2006 | 08:22 AM
MeanGreen97Z's Avatar
Re: Cam recommendation
cc503
Old Mar 6, 2006 | 08:28 AM
Javier97Z28's Avatar
Moderator
Originally Posted by MeanGreen97Z
cc503
Old Mar 6, 2006 | 09:43 AM
shannons86's Avatar
I think you would like the new XFI cam from comp. the number is 07-467-8. That would work great with the beehive springs.
Old Mar 6, 2006 | 10:18 AM
Cmr0z28's Avatar
Cc503
Old Mar 6, 2006 | 10:29 AM
pele000's Avatar
What type of times are you running with your current combo?
Old Mar 6, 2006 | 05:48 PM
aboatguy's Avatar
I don't go to the track! I am just trying to have a decent street car.
How's the 503 compare to the 305 and 306?
Looking at the CC chart it looks like it is a step down from the 305, but I am not a cam expert.
I'll check out the 07-467-8
Mike
Old Mar 6, 2006 | 06:09 PM
JustNO's Avatar
cc503 ?? His heads flows 275cfm @ .600 I think he deserves bigger than 503 CC306 (230/244) or GM847 (234/242) would be better I think.
Old Mar 6, 2006 | 06:41 PM
96capricemgr's Avatar
I have a
58mm TB
Electric H20 pump
4L60E
3.45 rear end gears
285/40/17 tires
Seems several of you are missing the details I highlighted.
I might try one of the XFI grinds under 220 on the intake
Old Mar 6, 2006 | 06:48 PM
JustNO's Avatar
So?
I know lots of people use GM847 for their street car. If bigger than 220 is not for daily car there would be a serious problem here
Old Mar 6, 2006 | 08:49 PM
how about the power off the line with just a 2800 and only looking to go to about 6200. The 847 fit those criteria too?
Old Mar 7, 2006 | 12:57 AM
Peak at 6200.... he doesnt wanna spin this motor to the moon. CC503 and dont look back. I think its actually a step up from the 305. Duration is the key.
Old Mar 7, 2006 | 07:59 AM
aboatguy's Avatar
Thanks for all of the input. I probably added a false premise. I don't mind spinning past 6200. I was trying to show that, I would rather have solid power across the rpm range vice a strip only cam that had a 3800-7500 power band.
Sorry if that caused any problems. I believe that I want something hotter than a hotcam/ CC305; looking at the CC website the 305's operating range is 1500-5500.
Mike
Old Mar 7, 2006 | 08:15 AM
aboatguy's Avatar
Thanks, how does it compare to the 847 and will it idle?
Old Mar 7, 2006 | 08:28 AM
blkchevyz's Avatar
just do a custom cam. your going to get the most out of it, and still be streetable.
your heads flow pretty damn good so your not going to have to run a huge cam to get decent power out of it.
i would just call up one of the many companies that can grind a cam, and just tell them what you told us.
you wont be disapointed
i have a custom from http://www.futralmotorsports.com/
similar to the 306 i replaced it with, but made alot more power
