Cam Reccomendation.
Old Jan 4, 2005 | 11:22 PM
c0rey's Avatar
Cam Reccomendation.
Here are the Mods:
1996 Z28
Line Lock
Wilwood Proportioning valve
!ABS
ATI Procharger D1SC
Dual Intercoolers
Walbro 340 Fuel Pump
Lucas 42.5lb Injectors
Taylor Wires
OTVC Looms
NGK TR6 Plugs
ODB1 PCM4LESS Coversion PCM
LT4 KM
Jet Hot LT's
Hooker Y Pipe
Magnaflow Catback
Granatelli MAF
Throttle Body Bypass
!Air
!EGR
Boxed Subframe connectors
Vigilante 3600 Stall
Here is the cam that cmotorsports said would be best for my setup. What do you all think?
Comp Cams TS224XL Camshaft 224/236 duration @ .050", .536"/.555" lift with 1.6 rockers, 114lsa. Nitrous/supercharger camshaft, designed for engines running up to 150 shot N2O, 5-12psi supercharger.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
