CAM question
Old Feb 27, 2003 | 04:40 PM
Supermanx500's Avatar
CAM question
I was told on this message board that the biggest I should go is
XE Cam 236-242
Lift .521 - .540
LSA
RPM Range 2500-6000
I am also getting with this
racenet.com's Lt1 Cam Package W/1.6
Heads Decked and Port and polished.
3.42 rear end
This cam Going to work ok.....?
Old Feb 27, 2003 | 05:09 PM
FastGuyJR's Avatar
FWIW, some people on here have had bad experiences with racenet, some good, buyer beware.
I would definitely look for an alternate place to have your heads ported and polished. Some of the guys on this board will do a very good job on them (Skaradom, Nighttrain66) for a good price.
That cam is nice. You will need PCM tuning to be able to drive it like you want to though. I recommend 3.73 gears for auto and 4.10 for M6, unless you're adding a power adder later (Supercharger, turbo, or nitrous).
JR
Old Feb 27, 2003 | 05:17 PM
stik6shift93's Avatar
I'd go with a bigger gear than that, you'll also want a big stall conveter.
Old Feb 27, 2003 | 05:35 PM
Grease's Avatar
The cam will work with ported heads but it will be on the wild side. A couple of people have used that or similar cams on stock heads. But lke mentioned above, you'll need tuning to make the car run right and more gearing won't hurt.
As for racenet.com, I've been buying stuff from them for 3 years now and I've never had any problem. Its a fact that when someone is happy, he tells 3 people, when he is pissed off he tells 9 people and those 9 people tell 3 other people. So it only takes 2 or 3 people for a company to have a bad reputation. When you sell as much stuff as they do, you're bound to have a few unhappy customers.
That being said, my heads are with SkarodoM right now
Old Feb 27, 2003 | 05:38 PM
Very good point, I see a lot of good companies that have gotten bad raps. We need more positive feedback like this, so people don't get the wrong idea about companies.
Old Feb 27, 2003 | 09:11 PM
I am getting my heads P&P and Decked at a local shop......
I am getting PCM for Less to get it tunned and then going to the dyno and getting it tunned there too
What type of RWHP gains should I expect?(on average)
I want my car to be on the wild side......I am getting a everyday car so i can just take this out on saturday nights
Oh ya and I have like evey bolt-on besides TB.....and I have a Custom high stall TQ
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
