cam question
Old Apr 1, 2006 | 07:39 PM
niceZ28's Avatar
cam question
just wondering what kind of job it is to swap cams on a 95 Z28, not sure if engine has to come out or not, any info would be graet. thanks
Old Apr 1, 2006 | 07:49 PM
ibanez6rg's Avatar
Re: cam question
It's a project that a lot of people tackle. With the help of a friend or two it can really be done in a weekend. The engine does not need to come out. I had a lot of fun doing it.
Old Apr 1, 2006 | 08:28 PM
niceZ28's Avatar
Re: cam question
am i correct when i say it is behind the water pump and distributor?
Old Apr 1, 2006 | 08:30 PM
niceZ28's Avatar
Re: cam question
it is behind the water pump and dist. ?
Old Apr 1, 2006 | 08:40 PM
ibanez6rg's Avatar
Re: cam question
Yes, you are correct.
net_coma's Avatar
Re: cam question
yes all of that must be removed to make room. you must have enough room to put the cam in front of the engine and slide it into the cam bearings. The intake has to come off so the lifters can be removed and reinstalled. valve covers off to loosen and adjust the rocker arms.
Old Apr 1, 2006 | 08:42 PM
ibanez6rg's Avatar
Re: cam question
BTW, you will also have to remove the A/C condensor and radiator.
Old Apr 1, 2006 | 11:40 PM
FastZinTennessee's Avatar
Re: cam question
It was close but I didn't have to remove my A/C condensor. I was able to remove the radiator and get enough clearance. The condensor can be moved a little forward to get the necesary room.
Basically everything on the front of the motor has to come off- crank pulley/hub, waterpump, distributor, timing cover (you must drop the front of the oil pan down a little to remove the cover), then the valve covers and intake manifold need to come off.
The only really time consuming/crappy parts are dropping the front of the oil pan and adjusting the rocker arms.
Old Apr 2, 2006 | 01:01 AM
lt11997's Avatar
Re: cam question
It's fairly easy, just takes alot of time. And don't do what I did and rip the oil pan gasket. The hardest thing for me was to adjust the rockers (took me 2 times).
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
