Cam ONLY / STOCK HEADS guys please (rockers OK)
Old Jan 30, 2004 | 05:21 PM
  #16
Frank95z's Avatar
Fastbird I run the Crane 210/224 stockheads na. My race weight when trying to go fast is 3165. I ran 11.40 116.59 with a 1.48 shorttime. Lightweight car,baby cam,Vig3200 = Frank95z
Old Jan 30, 2004 | 05:27 PM
  #17
Fastbird93's Avatar
Oh YOU"RE the guy I've heard of with killer times on that baby cam!!!!
Old Jan 30, 2004 | 05:41 PM
  #18
Projectz28's Avatar
Moderator
Stock head
cc305, crane 1.6 rr, slp cold air.
hooker LT's, custom 3" Y. cutout and flowmaster catback.
10 bolt with 3.73's, yank ST3500 converter.
LT1 edit, car is full weight (3650lbs)
times and dyno in sig, but I dont know if I belive the dyno numbers all that much because I couldnt get the converter to lock.
Old Jan 30, 2004 | 05:52 PM
  #19
IllusionalTA's Avatar
Geez.. There might be a new cam only guy coming to town.. just hopefully i can get this pig down from 3900lbs.. a buddy of mine has p/p heads and a hotcam is only trapping 112mph.. think he might just be missing some power in the tuning.. we'll find it somewhere.
Old Jan 30, 2004 | 05:53 PM
  #20
94formulabz's Avatar
Originally posted by Fastbird93
Where's the guy with the 218/224??? I DEFINITELY want that one in on this post too.
well, i dunno if you where looking for me or frank with his 210/224
Joe97SS also runs the cc502 i believe.
anyways:
SLP 2OTL Catback Exhaust
SLP Headers
Catco 3" Cat / ORP / Dynomax Bullet ORP
Comp Cams XE 218/224 111LSA
1.6 ProMag Rockers
CSI Electric Waterpump
52mm Throttle Body
3.73s + nittos + Prokit
12.846@ 111.3 1.95 60'
http://www.personal.psu.edu/users/b/...o2/dyno351.JPG
thats 343 SAE
My car is heavy, full weight plus sub and heavy bmr suspension and my 240lb ***. I need to get a new clutch in to improve my 60', and toy with my shiftpoints by a couple hundred rpms. I'm not expecting anything earthshattering improvements, but i know that i'll get a lil faster this spring.
-brent
Old Jan 30, 2004 | 06:10 PM
  #21
Frank95z's Avatar
I like to bracket race and to run fast I run my combo on the edge. With that said I ran the 11.40 in 60 degree air, good but not killer. I went out once in cold air and had tuning issues (false knock) and only ran 11.40's. I have since resolved that problem but I'm now ready for bracket season and have my bracket setup in the car. In cold air I know i can run 11.20's but that will have to wait till fall. Given the flow of stockheads I believe that a smaller cam is the way to go. I made 331 rwhp with my car but that was thru a 12bolt rear with a Vig3200 unlocked. Frank95z
Old Jan 30, 2004 | 06:19 PM
  #22
bad96firechikin's Avatar
....I don't have a 12 bolt, and a good short time is hard to get since I have a McLeod Street Twin for a clutch
I've always lusted after that clutch...why is it not good for 60 ft times?
Old Jan 30, 2004 | 06:24 PM
  #23
Fastbird93's Avatar
It's too grabby. You need slicks to cut a good short time. It's a no-slip clutch. Nice, but hard to launch.
It will be AWESOME on slicks and a 6K dump!
Old Jan 30, 2004 | 06:26 PM
  #24
That's what I'm talkin' about!!! Guess you're just waiting for the old 10-bolt to go out first???
Old Jan 30, 2004 | 06:31 PM
  #25
Fastbird93's Avatar
Yup. But I'm not on slicks either. Not on anything right now for that fact. Still sorting out issues.
Old Jan 30, 2004 | 06:35 PM
  #26
Yea, I just read your other posts...sounds like you're at your wits end. I guess hotroddin' will do that to you though. I just went through a 4 month emissions ORDEAL....Just out of curiousity, do you still run the original one-wire O2s, or have you switched to heated O2s? Not that this would cause your problem b/c you said they look ok on the scanner, just curious.
Old Jan 30, 2004 | 07:48 PM
  #27
Kain's Avatar
See sig for my best stock head time. I still had the stock 1.5 rocker arms on back then too.
Old Jan 30, 2004 | 08:16 PM
  #28
MauriSSio's Avatar
the most important thing to look at to make an accurate comparison powerwise would be the avg. MPH (trap speed) and race weight.Also, Looking only at the best runs isnt a very accurate measuring tool and CAN be misleading
Old Jan 30, 2004 | 09:04 PM
  #29
Moore94Z's Avatar
SLP headers, cutout, SLP CAI, XE 224/230(the lowest lift version from CMS). #'s in sig.
Old Jan 31, 2004 | 03:11 PM
  #30
Well hopefully i'll be able to beat my bolt on best of 12.73 and my most recent accomplishment of a 12.90@108 @3933lbs The street twin is the best clutch on the market hands down.. But a 10bolt wouldn't be a happy camper on slick's.. BOOM!!!
