Cam only car which cam
Old Mar 19, 2008 | 12:46 AM
  #16
bombebomb's Avatar
You guys think I should just throw the stocker in it for now and get them matched later, thats kinda what I would like to do, but my money loaners are saying, put new cam in now. IMO I should wait.
Old Mar 19, 2008 | 06:15 AM
  #17
LTBlackBird's Avatar
Originally Posted by bombebomb
Iv also thought about AI, and I am going with AI to port my heads when I do I think. Maybe I should look into them?
I've been nothing but pleased with my results from them, they even contacted me after seeing my numbers online to find out which cam they had given to me for reference. Between LE, AI, and others, i would go back to AI
Old Mar 19, 2008 | 07:03 AM
  #18
2000GTP's Avatar
I think you should wait, otherwise, you are going to be mismatching parts in my opinion and you will not have a well running setup.
Old Mar 19, 2008 | 12:05 PM
  #19
bombebomb's Avatar
do you think I will have to worry about spun bearings.
Old Mar 19, 2008 | 12:44 PM
  #20
gatorhead's Avatar
Either I am confused or you are getting a lot of bad info so far!
I would not recommend any of the cams listed so far for a 383 and ported heads. It won't be very efficient if you do so!
The reason I say this is that the additional dispalcement makes that cam even smaller than what it is. Not that small is bad.......trust me I know this and I have one listed below in that same class. If you have entered your info correctly on that site then it will show you from THEIR product line which is best, better, good from what you enter as your goals.
The custom cams suggestions are not part of this response
I am building a 355 with that same compression. When I submitted to Comp for a custom grind they pointed me to look at the cc465. That is their version of a torque monster, places the hp @ 400 and tq @ 520 on that program. It has low duration and high lift. I still don't think that is even an appropriate choice for your 383. I am going custom btw.
You have to decide what your goals are, establish them and go from there. Good luck with your build!
Old Mar 19, 2008 | 04:20 PM
  #21
bombebomb's Avatar
I was only asking for a cam only, but I can understand your confusion thanks for your knowledge!
Old Mar 19, 2008 | 07:00 PM
  #22
monkeyoflove's Avatar
for a cam only car I love love love my Crane 227
Old Mar 19, 2008 | 09:53 PM
  #23
brain's Avatar
I didn't worry about it on my first cam, thinking it was all internet hoopla and spun a bearing in 500 miles. Next time I did it right and dropped the pan and put in a new oil pump with a white spring. Cheap insurance...too many people spin them too many times for it to be a coincidence. It's been thousands of miles on the cam now with no issues. I'd STRONGLY recommend it.
Old Mar 19, 2008 | 10:01 PM
  #24
bombebomb's Avatar
So many things to think about. Ill keep this in mind.
Old Mar 19, 2008 | 10:54 PM
  #25
Steve0's Avatar
Do you have any limits on how high youd be willing to rev the car. For a 383, I'm sure you can get away with a bit more cam than a cc503. If I was spending the money to go 383, I'd spend the extra $100 and go custom...
Old Mar 20, 2008 | 12:08 AM
  #26
bombebomb's Avatar
limit is stock pcm limit which I believe is 7k so rev to about 6800 is max id say.
Old Mar 20, 2008 | 02:52 AM
  #27
gatorhead's Avatar
Cam only I would HIGHLY suggest taking a close look at the cc465 then.
Following is from Comp:
Here is the spec card information you requested.
SUPERB LOW END AND MID-RANGE
COMPETITION CAMS PART NUMBER: 07-465-8
ENGINE: LT1 260XFI HR-13
GRIND #: LT1 260XFI HR-13
INT EXH
VALVE ADJUSTMENT HYD HYD
GROSS VALVE LIFT: .560 .555
DURATION AT
.006 TAPPET LIFT 260 270
VALVE TIMING OPEN CLOSE
AT .006 INT 21 59
EXH 72 18
THESE SPECS ARE FOR CAM INSTALLED
@ 109.0 INT C/L
INT EXH
DUR @.050: 210 218
LOBE LIFT: .3510 .3480
LOBE SEPARATION: 113.0
RECOMMENDED CC VALVE SPRINGS: 26915
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Queens94z28
Nov 20, 2014 06:03 PM
