Cam lift and rocker ratio questions
Old Sep 16, 2003 | 07:48 AM
JohnsSS's Avatar
Question Cam lift and rocker ratio questions
I have an lt4 hotcam that lift's .525/.525 w/ 1.6 rockers which I noticed in the post specs info. I have these rockers.
My questions:
Are other cams specs for LT1's shown assuming that you have the stock 1.5 rockers?
Approx. how much will 1.6 rockers adjust the lift specs of the cams?
i.e. Comp Cams "Extreme" LT1 Camshaft, 224 / 230, .502 / .510 112 LSA, if the first question was yes, then what would the lift of this cam be? apprx.
Thanks in advance
Old Sep 16, 2003 | 08:02 AM
383Z4ME's Avatar
Most cams spec 1.5 rockers
Lift would be about .535/.544 and the duration numbers would be 2-3 higher like 226/232
Old Sep 16, 2003 | 08:33 AM
OldSStroker's Avatar
Re: Cam lift and rocker ratio questions
Multiply the lift by 1.6/1.5 or 1.0667.
.500 becomes .533
.525 becomes .560
etc.
Total lobe duration doesn't change of course, and .050 duration at the lifter, where it's rated doesn't change, but the valve gets to the original .075 lift point (based on 1.5 ratio and .050 lobe lift) a little sooner, so some folks consider it to have a little more duration.
My $.02
94formulabz's Avatar
simply divide lift by 1.5 and multiply by 1.6.
Leave the duration alone. The .006 or .050 tappet lift occurs at the same spot reguardless of what rocker is used.
-brent
Old Sep 16, 2003 | 08:35 AM
darn it, i was too slow, I got beat by the old guy!
-brent
Old Sep 16, 2003 | 03:32 PM
JohnsSS's Avatar
haha, sorry u got beat, thanks for the quick response
Old Sep 16, 2003 | 04:27 PM
-brent
I usually get beat on the tree however...
I leave on the first yellow and still have a .600 light!
I'm going to start leaving when the stage light comes on!
LeftoverChinese
Jan 14, 2024 03:03 PM
oldschool
Feb 9, 2016 09:21 PM
Roadie
Feb 16, 2015 10:34 AM
1775.Z28
Jan 11, 2015 10:51 AM
