Cam lash adjustment
Old May 16, 2017 | 07:37 AM
KYWes's Avatar
Cam lash adjustment
So I re-adjusted my lash recently. I'm sure I had them too loose. The engine sounds quieter now and runs well but I have an uneven idle kinda like a lope but the cam isn't that big and again it's uneven.
Would that point to my having adjusted the lash too tightly on a couple of cylinders? What would be the symptoms/effect of having the lash too tight?
Old May 16, 2017 | 09:03 PM
Re: Cam lash adjustment
Too tight will be a roughness or lope when there should not be any.
Old May 16, 2017 | 09:12 PM
KYWes's Avatar
Thanks for the reply Rob and the confirmation. Guess I adjust them again. Is there any process you'd recommend? Do I just back off a bit, Do I need to loosen them, let them "release?" and then adjust them?
Old May 16, 2017 | 11:37 PM
From Rob's website:
4th Gen LT1 F-body Tech Articles
Old May 17, 2017 | 07:45 AM
KYWes's Avatar
Duh! Much as I've been on your site I should have been aware of this. Thanks again.
