Cam install update #2 w/fugly plug pic
Old Jul 2, 2004 | 02:36 AM
truedualws6's Avatar
Here is the picture of the fugly plug: Plug Pic
After seeing this I can see why the Bosch +4 plugs may not be so
good. Too much area for stuff to stick too. Although the car was
running fine, it would not have been much longer before #8 would
have started to miss. All the other plugs looked OK. I am hoping
that new valve stem seals will take care of this.
Now for the day four questions:
Q1) How critical is the alignment of the crank hub? I marked it as
best I can but can see that the accuracy is maybe 5-10 degrees.
Q2) What is the correct length of stud to use as a guide when
installing the intake? I need to buy or make some.
Q3) What is the best RTV to use on the front and back of the intake?
I have regular black and the high temp red stuff.
Q4) Is a re-torque of the intake necessary (after like 24 hours)?
Some of my intake bolts seemed a bit loose during the removal.
Q5) My optispark has 30,000 miles on it and I also have a new one
in the box. Should I install the old one or the new one?
I finally did a mock up of the valvesprings. The Comp 26915 springs
will work but I need to go with the +.050 super locks and will end
up with an installed height of 1.77". I had to order different retainers
to go with the super locks (which I had), so the springs can't go in
until Saturday. With regular locks the height was 1.72" so I definately
need the +.050".
I now wish I would have planned to pull the heads and do a simple
port matching job. It would have been nice to clean up those ports
but I just don't have the time now.
Old Jul 3, 2004 | 04:14 PM
One more try for comments on the plug. Will installing new valve
stem seals resolve the oiling problem on the plug?
Old Jul 4, 2004 | 10:29 AM
TrouserSnake's Avatar
hey... My plugs get nasty and foul out all the time after the cam change after about 20 minutes of run time.. Also the left bank O2's would not swing... Then I think Neither bank would...
The only code I was getting was injector circut
Old Jul 4, 2004 | 11:06 AM
joeSS97's Avatar
Crank hub isnt that critical.You should be able to get it close.I used a couple old drill bits to align the intake,just so you dont slide it forward and rearwards a lot.Use high temp copper RTV.The opti is up to you.
Old Jul 4, 2004 | 11:43 AM
blown383's Avatar
you can also just use pencils to help you align the intake.
-B
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
