cam install nightmare
Old Sep 23, 2003 | 07:27 PM
Ws6Envy's Avatar
ok...the install went good...i only had to rig one thing and thats the timing set. I put a new cam sprocked and chain on a old (130k mile) crank sprocket.
the motor started right up...you had to press the gas like a carb. motor otherwise it would die at idle.
also it didnt rev up as you gave it more gas.
now sometimes it will start but no matter how much gas you give it...it wont stay running.
any ideas?
TPS is fine, coil is fine, plug wires are correct....where do i begin
madwolf's Avatar
Your rockers are too tight.
Old Sep 23, 2003 | 07:28 PM
Ws6Envy's Avatar
really....i have to pro mags....any tips on how to adjust them
Old Sep 23, 2003 | 07:30 PM
madwolf's Avatar
Check shoebox's website here.
Old Sep 23, 2003 | 07:40 PM
96speed's Avatar
Timing chain might be off. You 100% sure it was installed correctly?
Ryan
Old Sep 23, 2003 | 07:45 PM
Ws6Envy's Avatar
it went dot to dot and the cam was at 3 o clock
Old Sep 24, 2003 | 08:21 AM
Ws6Envy's Avatar
does everyone agree with the rockers being too tight?
Old Sep 24, 2003 | 08:27 AM
grygst76's Avatar
opti installed correctly? rockers too tight would be number one especially if you are asking how do you adjust them
Old Sep 24, 2003 | 08:35 AM
bradpreece95z28's Avatar
I agree with the rockers being too tight . No offense, but if you asked how to adjust them they are too tight.
Go re-lash them and start the car, then while the car is running pull the valve covers off and back them off till you can hear them clack. then tighten them till they cease to clack loudly. In the case of pro-mags, Some noise is acceptable.
Old Sep 24, 2003 | 02:09 PM
Ws6Envy's Avatar
ok...i read shoeboxes website and it said to hand screw the rocker nuts on and that will be close to zero lash...im going to do this tonight and ill post the results.
Old Sep 24, 2003 | 02:28 PM
94formulabz's Avatar
hand tight is definitly zero lash. Even if you have gorrilla strong fingers and go a few degrees past there is going to be a larger varience in how many degrees you turn them with the wrench anyways.
You do understand WHEN to adjust which rockers though right?
Old Sep 24, 2003 | 02:38 PM
Ws6Envy's Avatar
i understand kind of...but any tips will be appreciated
Old Sep 24, 2003 | 02:49 PM
PatriotTA's Avatar
It could be the rockers.... never had to adjust them yet (still have the stockers) so I can't help you there. But, before you take off your valve covers, double check all your vacuum lines. Make sure there are no hoses that have been left off or mis-routed. Also verify that the right spark plug wires are on the places on the opti. Shoebox has a diagram on his website. HTH
Old Sep 24, 2003 | 02:52 PM
Ws6Envy's Avatar
what vaccume lines really play part in allowing the motor to start?
i know the wires are correct on the opti
Old Sep 25, 2003 | 05:46 AM
Ws6Envy's Avatar
adjusted rockers last night....helped a lot....and now it idles fine....better throttle responce but still hesititates under load untill it get above 2500rpm.
more adjusting?
