Cam help!?
Old Aug 4, 2007 | 12:41 AM
hotrod18_69's Avatar
Cam help!?
I just pull a cam out of an LT1 a friend pick up for $300.
Cam doesn't look like an of the other stock one's i have pulled out before..
The only numbers i can find are
705 15f 9040 GMPT BC These are on the end of the cam
02899 1106* These where one the shaft
I don't even know where to start looking for these numbers.. Anyone know anything i don't?
Old Aug 4, 2007 | 12:09 PM
Anyone one wannna take a stab at this?
Old Aug 4, 2007 | 08:15 PM
Phatcaprice's Avatar
Is there a stamped # on the back of the rear journal? Searches in google for ' "GMPT-BC" cam ' turn up stock LT1 and LT4 related problems with these #'s, but nothing concrete as to their specs. I saw one site where it was said that the numbers you have are core/casting numbers, not part numbers, and that there should be a 3 digit number on the rear cam lobe around the dist gear, or on the very back of the rear journal.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
