Cam help??
Old Mar 30, 2006 | 11:59 PM
Meen95z's Avatar
Question Cam help??
I just took out my lt4 hotcam and put in a 306 cam. To set the timing, I got the number 1 cylinder at tdc and lined up the marks on the crank and cam gears. A local engine builder says I have to use a degree wheel to set it at the right centerline. Suppose to be 108 I guess. Anyone have any idea on what hes talking about. I havent dealt with this before. Thanks
Old Mar 31, 2006 | 01:04 AM
sssalah's Avatar
Re: Cam help??
Using a degree wheel will tell you how much ICL you actually have your cam installed on. There's little you can do to correct it if its wrong.
Old Apr 6, 2006 | 06:40 PM
plattted's Avatar
Re: Cam help??
I believe that #1 cyl @ T.D.C. is when the dot on the cam gear is @ the 12o' clock position. When the dots are opposite each other,12 &6 the #6 cyl is @ T.D.C.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
