Cam to get every little HP possible?
Old Jan 25, 2004 | 02:40 PM
96YenkoClone's Avatar
I do a computer test here for emissions, the dont do a breather on OBDII, I've heard anything less than 112 LSA is too rough for the computer to pass the car. I dont want to change to a solid roller setup yet cause I just built the motor hydraulic roller. So I am looking to change the cam only, I think my springs go to a .600-.610 lift.
My setup is a cast SCAT 3.75 crank, PM rods rebuilt, speed pro hyper pistons, fully ported lt1 heads, 1.52 rockers, 2.00/1.55, comp cams beehive springs. oh 2 bolt main with arp bolts
I also dont want to really push my rpm limit although I do want everything i can out of this motor because I dont plan on spraying, my goal is in the 11s on motor, i dont mean like 11.99 know what i mean lol
Just give me some ideas, because this is my 3rd fbody but only the first ive modified, so im new to this stuff. Need all help I can get. Thanks again
The cam someone recommended was 236/242 .585/.596 112LSA
Can I get any more aggressive and what rpms will they probably take me too. If 112 is emissions safe and 110 isnt, can I get a custom grind 111 to pass. Need INFO???
Old Jan 25, 2004 | 03:16 PM
simple's Avatar
well if you want to squeeze every bit of power out of a cam and still pass emissions, dont buy an 'off the shelf' cam. have someone taylor a cam to your specific car and needs!
and a custom ground cam doesnt really cost that much more then an off the shelf grind, especially if you figure in the potential of it over the other IMO
Old Jan 25, 2004 | 04:35 PM
Old Jan 25, 2004 | 04:53 PM
93Z286Speed's Avatar
i agree 100% with that
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
