CAM Dyno Time Today - Any Ideas?
Old Mar 20, 2005 | 10:07 AM
truedualws6's Avatar
OBDI PCM Solves Mystery Problem - Jeff @ CAM Rocks!
My problem was best described by the dyno graph in my sig. Jeff from CAM
came back out here to So Cal this weekend and solved the problem with
OBDI.
The list of new/replaced parts to solve this problem included: OBDII PCM,
MAF, opti, coil, ICM, valve springs and spark plugs. I'm not sure if an OBDI
PCM will solve my consistent 2-3* of KR at WOT since I don't have a PCM
yet. Next step is to buy one, send it to Jeff for the program, install a KS
and drive the **** out of it.
Thanks again Jeff Creech/Carolina Auto Masters, Tuning Technologies,
and Mike/SS MPSTR. It was also nice to meet some fellow fbody
enthusiasts and talk shop.
Once I get the new dyno files I will update my sig.
Last edited by truedualws6; Mar 21, 2005 at 11:53 AM. Reason: Update with solution to problem
Old Mar 20, 2005 | 10:13 AM
stereomandan's Avatar
Re: CAM Dyno Time Today - Any Ideas?
I can't really help you out, only give you some words of encouragement. Good luck finding the problem. I know it's been a pain in the butt trying to figure it out. If you are getting KR, I can only think of a few things:
Comp-R's(big hassle to replace with OE lifters to see if they are the problem)
Bad knock sensor(wrap threads in teflon tape, reinstall, and see if KR goes away)
Timing Chain causing excess noise setting off the KR?
Good luck Mike. I like your setup, and want to see it run right.
Dan
Old Mar 20, 2005 | 12:01 PM
Thanks Dan. I'm trying to keep a positive outlook on this, but I have
my doubts if we will discover anything new. I'm hitting the road in
a couple of hours and will put up a post once I'm back home.
Old Mar 20, 2005 | 11:56 PM
tireburnin's Avatar
Congrats on getting the problem fixed. And a BEAUTIFUL car.
Old Mar 21, 2005 | 12:36 AM
SS MPSTR's Avatar
Nice seeing you again, Mike. Glad Jeff got it figured out for you....Milkman comes through again, huh?
Thanks for the pizza too....mucho appreciated.
Old Mar 21, 2005 | 07:29 AM
I must have missed something. You got it figured out Mike?
Dan
Old Mar 21, 2005 | 11:33 AM
Yes. Problem solved with the OBDI PCM. Jeff brought the PCM along
to give it a try and it did the trick. Now I just need to buy one and
send it to him for the program.
Old Mar 21, 2005 | 11:34 AM
Sean,
Thanks. You will have to give me an update on how things went for you.
Old Mar 21, 2005 | 11:36 AM
You are welcome Mike. Keep me posted on your progress too. Maybe I'll
have an OBDI PCM by then and can stop by Tuning Technologies and
"make some noise" as Jeff calls it.
Old Mar 21, 2005 | 11:51 AM
1SlowFormula's Avatar
Glad you got it figured out! BTW, did you get it on the dyno, if so how did it do???
Old Mar 21, 2005 | 11:55 AM
308/329
Less than last time, but pulling strong all the way to the limiter.
Old Mar 21, 2005 | 12:11 PM
Originally Posted by truedualws6
308/329
That was with an untuned OBD-I computer, or did he have some sort of tune in it?
Old Mar 21, 2005 | 12:36 PM
It was tuned. I'm sure it needs a bit more tweaking, but that will have to wait
until June.
Old Mar 21, 2005 | 02:13 PM
slimdawson's Avatar
I hope he's back I was planning on riding up to CAMs to get some tuning done next week. Glad you got it worked out.
Old Mar 21, 2005 | 02:42 PM
SS MPSTR's Avatar
Left for Durham, NC this morning.
