cam dowel pin removal???
Old Feb 20, 2004 | 07:29 PM
96HOTZ's Avatar
I have a lt4 hotcam and the dowel pin is .3 inches and I believe the stock one is .608 inches, I need to remove the pin and put in a new longer one? Any suggestions or ideas on how to remove it?
Old Feb 20, 2004 | 08:33 PM
rocmemphis's Avatar
You will more than likely have to take it to a machine shop...or at least I had to do that with mine. They had to weld a slide hammer to the pin to get it out. They are in there pretty good
Old Feb 21, 2004 | 12:49 AM
Zerosheaven's Avatar
i broke a vice and a hammer trying to remove mine, if you know a shop near you take it there
Old Feb 21, 2004 | 01:02 AM
ibanez6rg's Avatar
I put the pin in the vise and twisted it out.
Old Feb 21, 2004 | 01:52 AM
cmotorsports.com's Avatar
Our tool for doing it is just a modified automotive dent puller that you can pick up at any auto parts store. Instead of the regular threaded piece on the end it uses a die grinder fitting (the part that holds the dowel of the cut off wheel, sanding roll, etc) to grab the dowel pin, tighten it down, a couple of smacks on the slide on the puller and voila. Out.
canbaufo
May 25, 2015 12:01 PM
chuyz28
Feb 19, 2015 12:50 AM
grabbem88
Feb 10, 2015 06:20 PM
sscott
Jan 17, 2015 04:30 PM
Queens94z28
Dec 20, 2014 09:11 PM
