cam dowel pin
Old Oct 24, 2005 | 05:03 PM
1badasZ's Avatar
Unhappy cam dowel pin
ive heard, but not sure, but is it possible that the cam is eating up opti's? i have the delteq system and i know that you only need the opti sensor with that. when i first put the delteq on the car ran like a champ for bout 3 days. then after that it started running maybe worse then before. ive changed plug wires and wires once and it still acts up. i donno what to do. anyone with the delteq ever had any problems with the opti box going bad? or am i gonna have to somehow shorten my dowel pin on my cam or something. and btw ive changed opti's also.
Old Oct 24, 2005 | 05:12 PM
sssalah's Avatar
Re: cam dowel pin
If the pin measures 0.62" from the cam face or there about then it should be fine.
Old Oct 24, 2005 | 05:20 PM
1badasZ's Avatar
Re: cam dowel pin
so that means i would have to take all that stuff back off and the timing chain to measure it?
Old Oct 24, 2005 | 05:36 PM
sssalah's Avatar
Re: cam dowel pin
If you have the cam sprocket thickness, then it can be subtracted from the 0.62" and you don't have to remove the timing cover to measure. With aftermarket cams there is some variation and measuring is required.
rideordie
Nov 5, 2019 04:52 PM
sscott
Jan 17, 2015 04:30 PM
Queens94z28
Nov 20, 2014 06:03 PM
Red97LT1
Aug 15, 2002 08:33 AM
