cam clearance, have some questions!!!
Old Jun 19, 2007 | 09:18 PM
plaf713's Avatar
i have a 383 stroker, and most of the motor is disassembled so i decided to go with a larger cam then what i am running right now. it is the xf1 292, if you dont know the cam the specs are 242/248 584/579. will i have an issues with cam clearance. how would i be able to tell if i do have a clearance issue? ANother question is how streetable is this cam, i know its not going to have much bottom end torq but i hear it makes good numbers.
thanks
paul lafreniere
Old Jun 20, 2007 | 09:13 AM
plaf713's Avatar
no one can help
Old Jun 20, 2007 | 10:28 AM
Z28SORR's Avatar
Only one way to know for sure. Assemble the engine and rotate it and CHECK.
Old Jun 20, 2007 | 10:45 AM
plaf713's Avatar
so when i get the cam in and i rotate the assembly, will i hear it hitting or feel it? or will it be something i wont feel until i get the car started?
Old Jun 20, 2007 | 05:40 PM
Kevin Blown 95 TA's Avatar
I use a tie wrap that is about .060 and I use it like a feeler gauge to go between the rods & cam and rods & block to check the clearance
Old Jun 20, 2007 | 08:23 PM
plaf713's Avatar
Originally Posted by SStrokerAce
What Rods???
this is my first time doing a cam swap and im pretty knew at doing engine work, i hasve been researching it and have came across people having clearance problems with the cam hitting the rod, now im not even sure what that means but im trying to get information from people like you who knows there stuff. so im sorry that i cant explain myself to well but theres no need to be an ***.
Old Jun 20, 2007 | 09:44 PM
SStrokerAce's Avatar
I'm not being a ***, but I can't tell you if you will have a problem or not without knowing what connecting rods you are running. I guess there is no need to answer that now though. Otherwise, turn the motor over and listen to hear something or it just stops spinning all together. Good Luck.
Bret
Old Jun 21, 2007 | 02:07 AM
racer7088's Avatar
Thumbs up
The lobes on your new cam are not really any taller so if you already had good cam to rod clearance on your 383 you should still have it on this cam as well. The base circle must be ground lower for more lift but the lobes can only be so tall since the cam has to go through the cam bearings. The Eagle H-Beams have very good clearance at 3.750 stroke and 2.100 normal journal size but many I-Beams will hit and need to be ground. I do 4.000 stroke LT1 engine's and can still use any cam I want with no reduced base circles needed. Like Bret said it is in the rods and how they are made or modified.
thanks
paul lafreniere
Old Jun 21, 2007 | 09:19 AM
plaf713's Avatar
i do have eagle forged H-beam connecting rods, if that helps. thanks for the help
Old Jun 21, 2007 | 10:58 AM
racer7088's Avatar
Thumbs up
You should be fine then although double checking is never bad. I have gotten two sets of "fake" Eagle rods and some of the other like SCAT's H-Beams are bigger up there and do hit earlier.
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
