cam change question..
Old Aug 4, 2003 | 11:09 PM
J's 82's Avatar
Alrighty, tearing into the engine to do the heads and cam thing..
putting in an XE 224/230.. I have always worked with new components and fresh rebuilds.. so the question is this should I bother replacing my stock lifters that have 50k on them? Or is it a waste of money better spent somewhere else?
I am also going to be the guinea pig and try out the new edelbrock heads.. though I may "improve" upon them if I don't like the way they look out of the box.. I will keep you all posted with numbers after it is all said and done..
Old Aug 4, 2003 | 11:57 PM
atljar's Avatar
Im still running the stockers with more miles than that. I just made sure they looked good when i did the cam swap.
Old Aug 5, 2003 | 12:15 AM
J's 82's Avatar
Thanks for the input.. I was thinking a good inspect and reuse was in order but this is my first roller setup, so wasn't completely sure. Mmm, flat tappets, showing my age..
Old Aug 5, 2003 | 12:33 AM
GhostZ's Avatar
I left mine in with my first cam change but will be swapping lifters with this upcoming cam swap for added insurance.
As long as there isn't any damage, collapse, etc...I'm sure you could use the stock lifters but you can pick up a set of CC lifters for under $200.
grabbem88
Feb 22, 2015 11:16 AM
blac94Z
Feb 18, 2015 11:36 AM
InfernalVortex
Jan 17, 2015 09:35 AM
birdblack
Dec 30, 2014 06:59 PM
