cam on budget
Old Mar 21, 2007 | 03:40 PM
Mortify's Avatar
cam on budget
I want to install my LE1 cam this spring but I need to run on a very tight budget (replacing clutch, roadtrips, ect.)... What do I absolutely need and what can I keep and use again?
This will be installed by myself.
By the way, the timing chain was replaced with the opti less than 2000 miles ago
Old Mar 21, 2007 | 03:58 PM
Dave1980's Avatar
we just went through a zillion posts about this one.
http://web.camaross.com/forums/showthread.php?t=507774
I really doubt much should be different for the LE1 cam, if it is similar to the 503
Old Mar 21, 2007 | 04:07 PM
Mortify's Avatar
Hmm wierd, search doesnt work for me... that thread shows me that I need certain things and someone that went all out... So far I already have the 1.6 RR and the cam, new timing chain and a opti... im thinking gaskets, pushrods and valvesprings
Old Mar 21, 2007 | 04:24 PM
Dave1980's Avatar
what kind of RR do you have? Are they self aligning? If they are non self aligning, then you will need guide plates with hardened pushrods. I would go with comp hardened pushrods whatever way I went. (cheap&good)
I would get the springs that bret recommends.
And yes you will need a timing cover gasket set.
Old Mar 21, 2007 | 04:58 PM
Mortify's Avatar
they are 1.6 SA, I am talking EVERYTHING that I will need... like gaskets and tools...
Old Mar 21, 2007 | 05:00 PM
2000GTP's Avatar
Shoebox has a cam removal/install on his site that also goes over what you'll need: http://shbox.com/ci/cam_removal.html
Old Mar 21, 2007 | 05:10 PM
Dave1980's Avatar
the type of spring remover you get will depend on if the springs will be double coil or single. FYI on the tool part
ChevyGuy
Parts Wanted
Feb 4, 2016 06:41 PM
alex5366
Feb 17, 2015 08:12 PM
pimpss96
Feb 12, 2015 01:28 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Jrlt1
Jan 3, 2015 07:38 PM
