cam on budget
cam on budget
I want to install my LE1 cam this spring but I need to run on a very tight budget (replacing clutch, roadtrips, ect.)... What do I absolutely need and what can I keep and use again?
This will be installed by myself.
By the way, the timing chain was replaced with the opti less than 2000 miles ago
we just went through a zillion posts about this one.
http://web.camaross.com/forums/showthread.php?t=507774
I really doubt much should be different for the LE1 cam, if it is similar to the 503
Hmm wierd, search doesnt work for me... that thread shows me that I need certain things and someone that went all out... So far I already have the 1.6 RR and the cam, new timing chain and a opti... im thinking gaskets, pushrods and valvesprings
what kind of RR do you have? Are they self aligning? If they are non self aligning, then you will need guide plates with hardened pushrods. I would go with comp hardened pushrods whatever way I went. (cheap&good)
I would get the springs that bret recommends.
And yes you will need a timing cover gasket set.
Shoebox has a cam removal/install on his site that also goes over what you'll need: http://shbox.com/ci/cam_removal.html
