cam bearings for cc306
Old Jul 5, 2005 | 09:03 PM
bumpnzx3's Avatar
i am using a cc306 cam in my current engine build. will standard durabond bearings work fine with this cam or should i have bought the "HP Race Series" bearings? to me- a cc306 isnt exactly a huge "race" cam. just curious as to what others thought. i would assume that most standard aftermarket bearings would be just as good if not better than the gm bearings?
this is going in an l98 engine- but i posted here because i thought this was a fairly popular cam with the lt1 group.
Old Jul 6, 2005 | 06:37 AM
bumpnzx3's Avatar
Re: cam bearings for cc306
bump
Old Jul 6, 2005 | 06:48 AM
Mystic97Z's Avatar
i used clevite bearings in my 357, have a cam a lil larger than an 847.
used fuderal mogel in my other engine w/ an le1 cam and blew that one up, not sure what happened.
Old Jul 6, 2005 | 06:52 AM
bumpnzx3's Avatar
i am assuming you mean clevite's standard bearings? if so- i think i am in good shape- since the 847 is a little larger than the cc306- and your's is even larger than that. thanks!
carl.froehlich
Mar 13, 2015 12:38 AM
StansZ28
Feb 19, 2015 07:39 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
