Cam bearing, take a look
Old Mar 17, 2004 | 02:48 AM
  #16
jtk's Avatar
jtk
thunder racing sells cam bearings that are suposed to be stronger than standard steel backed babbit bearings
Old Mar 17, 2004 | 02:52 AM
  #17
1racerdude's Avatar
HAPPY HOOKER is the name of a fixture to pull the LT-1.It bolts in the fuel rail bolt with the bolts that come with it.It might be a strange name for someone out of contry,but that's it's name.
Old Mar 17, 2004 | 02:53 AM
  #18
jtk's Avatar
jtk
yup, there are HD aluminum faced cam bearings made by clevite
those should last a long time compared to the stock babit ones
Old Mar 17, 2004 | 02:59 AM
  #19
1racerdude's Avatar
You can leave the air conditioning condenser in.If you can hook the chains to get it LEVEL so when it comes loose from the tranny it is level (only way it will come out without fighting it) that would be OK,but going back in I would rather be all assembled so I can see the seal on the back of the intake.
Old Mar 17, 2004 | 03:07 AM
  #20
1racerdude's Avatar
If you need any help getting parts I am distributor for clevitte and a lot of other parts. I also have a small engine shop in LA if you need help with selection of any other parts,Cam,heads,gaskets,ect.
Old Mar 17, 2004 | 03:24 AM
  #21
Dan_gearhead's Avatar
I have to decide first whether I should just try and change the outer bearing and leave the engine in or take it out to change all of them...I already have the cam,heads,gaskets...It's just the bearings I lack.
If you just change one bearing would that be bad? I'm thinking the clearance will differ from the old ones still there...could that lead to some inbalance of the camshaft or something?
Old Mar 17, 2004 | 04:09 AM
  #22
1racerdude's Avatar
You are correct in your thinking.It could cause the cam to be out of alignment.If it were me I would change all or none.
Old Mar 17, 2004 | 07:36 AM
  #23
Just talked to a local guy here, with way more knowledge than me, who's driving in super comp and he told me that it shouldn't be a problem knocking out the freeze plug on the back and install/take out from front/back new/old bearings..with the engine out...
Old Mar 17, 2004 | 08:18 AM
  #24
WS Sick's Avatar
What did the rest look like? If the fron is the only one that shows wear like that you can slap hammer just the front one out. on a side note, I would emery the thing and see how it cleans up and how much play it has after, its a soft metal so it could have gotten alot of those scars as youpulled th old cam out.
Old Mar 17, 2004 | 08:22 AM
  #25
I don't know, I just went home last night after I noticed that front bearing, I'll have to see if I'll be able to see how the others look in there after work today...I was really careful when getting the old cam out but I can't say if I caused some of that or not when removing it, it didn't "feel" like that though...
carl.froehlich
Mar 13, 2015 12:38 AM
StansZ28
Feb 19, 2015 07:39 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
