Cam Bearing Scratch
Old Jan 29, 2005 | 01:17 PM
94GreenZ28's Avatar
Cam Bearing Scratch
I just installed new cam bearings in my block. The tool I was using put 3 tiny scratches in one of my bearings. You can barely feel it with your fingernail. The bearings I used are the Clevite 77 SH-290 S which are pretty soft. Do you think it will be ok?
Old Jan 30, 2005 | 02:12 AM
1racerdude's Avatar
Re: Cam Bearing Scratch
If there are high spots they are hurt.To what degree,I can't see them.
Is the engine COMPLETLY stock. If it has heaver valve springs, high ratio rockers,cam,ect.you need the SH 1349 S Clevite brgs. I have had 2 sets of the others fail in built engines that didn't last a month. I had to re do one and the other someone else built and I pulled both and tore them apart and cleaned out the metal and new brgs and rings.
Old Jan 30, 2005 | 06:23 AM
94GreenZ28's Avatar
It doesn't feel like the scratch is lifted. I heard from another post that the SH1349S were too hard thats why I bought these, but if you had the SH290S fail on you twice I might as we'll change them to the SH1349S.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
StansZ28
Feb 19, 2015 07:39 AM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
