cam bearing replacement
Old Mar 10, 2005 | 06:02 PM
Zachz28's Avatar
If a motor has a spun bearing is it possible to pull the motor and just replace the cam bearings?
Old Mar 10, 2005 | 07:12 PM
Re: cam bearing replacement
I don't think I have ever seen a spun cam bearing. Most bearings that spin are rod or main bearings.
To answer your question, yes, you can pull the engine and replace just the cam bearings. If I pulled an engine, I would look at everything.
Old Mar 10, 2005 | 08:27 PM
Jameslt1TA's Avatar
Yes do like shoebox said and look at the other bearings too...not to big of a deal to replace them and chances are, since the cam gets the oil first the others may be damage...i may be wrong though.
Old Mar 10, 2005 | 09:43 PM
Zachz28's Avatar
i c, i was just wondering
Brandon Wittmer
Dec 20, 2014 09:51 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
