Is this cam alright for my setup?
Re: Is this cam alright for my setup?
You can't have your cake and eat it too. NA means get as high compression you can get with pump gas before detonation. A blower needs low compression because the boost will make actual compression a lot higher. If you build an ideal NA setup with let's say 11:1 compression, and throw 10 psi of boost to it, you are looking at probably like 14-15:1 compression which will destroy the motor. You need to build the motor for what is going to be designed for: low compression=blower.....high compression=NA. Your cam must also compliment a blower or NA. A blower needs more exhaust duration and less overlap while a NA motor needs more overlap (to a certain point). Do some more research and talk to the guys in the forced induction forum....they are very helpful.
MustangEater82
19
Sep 3, 2002 02:09 PM
