cam
cam
looking for best cam for dd 1995 trans am auto, 3.73 gears transgo shift kit k&n cai , as&m headers and borla cat back looking to keep stock stall so best cam and rockers with stock stall thanks.
Re: cam
Cc305 is one of the largest lift off the shelf cams that does not require replacing the torque converter although it would still benefit. There will probably be some replys that the cc305 is junk but if you dont wanna upgrade the torque converter then it is an option.
Re: cam
IMO both bits of advise you got plus the HOTCAM idea are all poor.
For stock stall I would do something like the Crane 227 or the Lingenfelter 211/219, I would also encourage you to reconsider the stall think.
I started with a ZZ4 crate motor cam which is 208/221 with stock exhaust manifolds, stock gears and stock stall. The gains I got as I finally gave it the gears, stall and headers it needed were huge and this is a smaller cam than even the ones I mentioned much less the other cams mentioned here.
Re: cam
Re: cam
Lloyd Elliott 223/230 .565/.565 112lsa.
Similar to a hotcam and cc503 and will pass emissions and have close to stock mileage. This cam will make more power throughout the powerband and should expect to see a 10rwhp gain over the cc503.With the growing popularity of custom grinds this is hands down on the best dd cams out there. The cam is supposed to work with stock converter buts suggested to run one for better gains. I would suggest if you dd it alot then something in the 2600-2800. If you just dont care about how it behaves on the street then by all means you can go up to a 3600 but how you drive it that will make that decision.
Re: cam
Hey thanks for the replys. The Lloyd Elliott 223/230 .565/.565 112lsa.
how much horsepower do you think i would have with my mods plus this cam and rockers. thanks I have no emissions where im from.
Re: cam
Why are you against a stall?
If you are only doing ONE, then the stall is better.
3 reasons why a stall is BETTER than a cam.
Similar gas mileage, if not better with a stall instead of cam.
faster.
easier install.
Most cams with a stock stall will feel like a pig down low and pull hard up top.
The stall is the opposite. It's an animal down low and slower up top.
faster.
easier install.
Re: cam
Hard to judge how much power the a4 sucks up vs an M6. I know cam only cc503 m6 cars were in the 340-350rwhp range so i would assume it be in the 350+rwhp range but yours being an a4 id say somewhere in the 330-340rwhp area with that LE cam.
