which cam?
Old Oct 5, 2006 | 04:07 PM
slp97camaro's Avatar
which cam?
okay so i decided to get a cam for my car, but the problem is i dont know which one to go with. Im getting my stock heads port/polished and everything buy the same guy im getting the cam from. below are the choices of cams that i can buy from him. im looking to get around 420rwhp. i have all the supporting mods, just need to decide which cam. Thanks alot!!
230/236@.050 .510/.520 and 544/555 112
224/224@.050 .525/.525 and .560/.560 112
234/242@.050 .538/.559 and 574/596 112, 114
234/246@.050 .530/.550 and .565/.585 112
217/225@.050 .505/.530 and .539/.565 112
217/225@.050 .485/.505 and .517/.539 112
the car i have is in my sig. ive tryed to search but i want to know which one would best fit my setup.
Old Oct 5, 2006 | 04:25 PM
Quickz1670's Avatar
Re: which cam?
I would go with a custom cam. It's not all about peak hp. Use calculators to figure out your dcr so you can get optimal HP/TQ across the curve.
Find out the flow #s and then decide.
Old Oct 5, 2006 | 04:29 PM
95z28_m6's Avatar
Re: which cam?
If u dont feel like all of that i would suggest the CC306 grind cam, just dont forget to upgrade your valvtrain.
Old Oct 5, 2006 | 04:42 PM
BUBBA's Avatar
Re: which cam?
I believe you would be happiest with the 217/225 336.67/353.434-------------538.68/565.5 w/ 1.6 RRs-------------if you are considering driving on the street as well as the strip. JMHO
Old Oct 5, 2006 | 04:47 PM
BUBBA's Avatar
Re: which cam?
oops---I forgot that you want 420 RWHP. In that case, I believe you are going to need alot of the "other" stuff that he can provide.
Old Oct 5, 2006 | 04:59 PM
chrism400's Avatar
Re: which cam?
That 3rd cam you are looking at with 1.6 rockers is a nasty one at 112 LSA. I think the 420 RWHP may be a bit ambitious although with the stock 10 bolt and M6, numbers will be good. It's gonna take more than a run of the mill port job and cam I can tell you that.
Old Oct 5, 2006 | 06:30 PM
ABA383's Avatar
Re: which cam?
I personally like the 2nd and 5th choice with 1.6s, but I'm partial to smaller cams with bigger lifts...420rwhp is a bit ambitious though, but numbers are just that...numbers...For a point of reference I run a 226/234 in my 383 which is considered a weenie cam by some...
The 2nd and the 5th choice will make for great street/strip cams...The 5th one reminds me of the LPE 211/219 cam which I used before my current cam and it was good for some high 11s/low 12s at 115...
--Alan
Old Oct 5, 2006 | 10:21 PM
Heatmaker's Avatar
Advanced Member
Re: which cam?
You got everything from mild to wild, on there. If you want 420 on a small cam you need some really radical heads,intake, and exhaust setup and maybe you might see 400 maaaaaaaayyyyyyyybbbbbbbbbbeeeeeeeeeeeeeee. But A larger cam should get you there easier... it's down to the heads and intake porting.
Old Oct 6, 2006 | 08:27 AM
chrism400's Avatar
Re: which cam?
--Alan
I completely agree with this post. I would lower your peak goal to 380 or so and get some torque to go with it.
Old Oct 6, 2006 | 03:06 PM
Re: which cam?
which of those cams is similar to the cc306? or which one is the cc306? im having both the heads and the intake ported, so im not worried about that...i just dont want to put too big of a cam in, and make less power
Old Oct 6, 2006 | 07:50 PM
chrism400's Avatar
Re: which cam?
I'd use the 280 XFI-HR13 Comp Cam. It's similar to the 306.
Old Oct 6, 2006 | 08:07 PM
Re: which cam?
i can only choose between the cams i listed. the reason, is because the guy im getting the cam from can get it for me dirty cheap, so which one of those, if any are similar to the cc306 cam? thanks
Old Oct 6, 2006 | 08:20 PM
chrism400's Avatar
Re: which cam?
The first one 230/236 is the same duration at .050 as the 306.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
