cam
Old Apr 7, 2006 | 11:35 PM
jadams94ta's Avatar
cam
i want to put a cam in my car . but i have a 112xxx miles on it . do you think its to many miles on the motor to do a cam
thanks
jason
Old Apr 7, 2006 | 11:40 PM
chrism400's Avatar
Re: cam
Nah, stick one in there.
Old Apr 7, 2006 | 11:42 PM
jadams94ta's Avatar
Re: cam
i was hoping some one would say that
Old Apr 7, 2006 | 11:48 PM
chrism400's Avatar
Re: cam
Hey, as long as you have good oil pressure - why not. Obviously put a new timing chain and valvesprings on it. I also did my front cam bearing too. Apparently the water pump drive puts alot of strain on that bearing. Mine was really worn. I spin the crap out of this thing and it just keeps getting faster.
Old Apr 8, 2006 | 01:31 AM
hvyss's Avatar
Re: cam
Just be clean about the install. Too many guys do a cam/head swap and don't follow a cleanleness pattern and end up getting crap in the motor causing a spun bearing shortly there after. At 112,000 miles go for it.
HVY SS
Old Apr 8, 2006 | 09:46 AM
mattbailey's Avatar
Re: cam
My first swap was at 113,000 miles. I pulled the motor and we swapped out for fresh cam bearings. The front cam bearing looked pretty bad, but the rest looked pretty good. No problems here and I've swapped cams again.
Old Apr 8, 2006 | 09:53 AM
Jazsun's Avatar
Re: cam
Its kind of hard to tell the state of the motor without being there, but if it revs good, has no ticks/taps, doesnt burn oil/ coolant etc.. Should be allright. Just make sure your not putting a cam in an already tired motor then your looken for trouble, and probably wasting your time.
Old Apr 8, 2006 | 10:21 AM
jadams94ta's Avatar
Re: cam
no tick or taps . it has good oil pressure for having a 112,xxx it runs very well . what would be a good cam for my car . it a bolt on car i also have a th400 with a 3200 stall so its not a ever day car . i want something that good for 1/4mile and i want to hear i have a cam in it to
thanks for the help guys
jason
Old Apr 8, 2006 | 05:48 PM
chrism400's Avatar
Re: cam
What gear do you run?
Old Apr 8, 2006 | 07:38 PM
jadams94ta's Avatar
Re: cam
no gears yet working on getting some 3.73. i dont want to go to crazy with the gears cause i only have a th400
Old Apr 8, 2006 | 07:53 PM
chrism400's Avatar
Re: cam
Well, you can always go with a custom grind, or an off the shelf cam like the XE 230/236, or the new XFI series cams. Mine is a bit on the small side but you can really hear it at 725 rpms where I have my idle set. It makes a boat load of torque and would work great with a 3.73 and 3200.
Old Apr 8, 2006 | 08:30 PM
jadams94ta's Avatar
Re: cam
ok sounds good onces i finish my th400 install i guess its on to the cam
Old Apr 8, 2006 | 08:34 PM
jadams94ta's Avatar
Re: cam
how big of a pain in the but is it to do a cam swap. an is there anything i should know about doing it
Old Apr 8, 2006 | 08:37 PM
BitterOldMan's Avatar
Re: cam
Since you are going to be pulling the tranny anyway.....yank the motor, it will be soooo much easier to do the cam swap when it is out. And, as long as it is out, replace the cam bearings and pop on a new oil pump. GM pump is perfectly fine. Then you will likely have no problems and be good to go for another couple of hundred thousand miles.
Old Apr 8, 2006 | 09:10 PM
jadams94ta's Avatar
Re: cam
i would have done that but im almost done the swap
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
