Which cam?? for 3.73 and 3000 stall?
Old Jan 21, 2006 | 05:08 PM
BadCamaro's Avatar
Question Which cam?? for 3.73 and 3000 stall?
I bought TCI 3000 and will install 3.73. The car is for daily driver and street racing. I am confusing which cam should chose to get most power and still getting the drivability…
Old Jan 21, 2006 | 05:54 PM
96m6lt1's Avatar
Re: Which cam?? for 3.73 and 3000 stall?
cc305 or little more aggressive like 230/236 112*would be sweet!
Old Jan 21, 2006 | 06:35 PM
LameRandomName's Avatar
Look for something for which the manufacturer claims that the powerband starts around 2000 and ends around 6500, give or take a few hundred on either end.
Old Jan 22, 2006 | 07:12 AM
BadCamaro's Avatar
any more?
Old Jan 22, 2006 | 07:41 AM
JustNO's Avatar
233/239
Old Jan 22, 2006 | 04:25 PM
BadCamaro's Avatar
How is Hot Cam *openning from idle*(218/ 228, Lift .525/ .525 112)with these parts (stall 3000 and 3.73)?
Old Jan 22, 2006 | 07:20 PM
1quickgt's Avatar
id say the cc305
Old Jan 22, 2006 | 08:21 PM
The Engineer's Avatar
I have the LT4 Hot Cam (like it a lot), w/ 1.6 RRs, 3.73s and Vigilante 9.5" 3200. Also, 26" MT 10.5 ET streets, Kooks and PCMforLess tune. Everything works really well together (cam, gears & stall) and I've been running 12.40s @ 110+. I believe the car with this combination has 12.10 potential, once I improve the launch and 60 ft times.
I don't think you can go wrong with the Hot Cam along with the 3.73s and 3000 stall!
http://www.cardomain.com/ride/2189634
Old Jan 23, 2006 | 12:46 AM
BadCamaro's Avatar
Question Re: Which cam?? for 3.73 and 3000 stall?
I found this Hot Cam with 1.6 RR only $250. So it will not be wrong choice if I buy it !!
Old Jan 23, 2006 | 07:18 AM
Javier97Z28's Avatar
Moderator
HotCam isn't bad, but I had really good luck with my XE 224/230 grind until my car bent a pushrod Saturday..
thenewkid
Apr 12, 2015 07:42 PM
thenewkid
Nov 27, 2014 09:41 AM
FormulaV8
Sep 1, 2002 03:44 PM
Teal94V-6
Aug 31, 2002 09:21 PM
veryslowfbody
Aug 22, 2002 04:31 PM
