which cam
Old Jun 9, 2003 | 01:33 PM
97WRAITH's Avatar
which cam
Called Comp Cams and they told me that with my mods to go with a XE07-501-8 212* 218* @ .050" .488int .495exh 112lsa 4* advance the guy said that the cc305 was too big. I know it isn't too big. What should I get. I need to pass emmisions.It is not my everyday car.
Thanks!
Rob.
Old Jun 9, 2003 | 01:49 PM
97WRAITH's Avatar
Anyone know the number toll free perfered of Cmotorsports?
Thanks!
Old Jun 9, 2003 | 01:51 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
goals?
how high do you want to rev?
heads?
I say 224/230 on a 110 LSA since you have a 6spd... but your goals/limits may varry
Old Jun 9, 2003 | 02:36 PM
97WRAITH's Avatar
Trey I am not to knowledgable on cam choices. My motor has 100,000 miles on it. What could I rev it to safely?
Thanks for the reply.
Old Jun 9, 2003 | 02:57 PM
treyZ28's Avatar
i wouldn't hesitate to rev 6400, maybe even further to 6600 depending on how terrrible of a situation a spun bearing would create
i'm no cam expert but i think a 224/230 on a 110 would best suit your needs
http://web.camaross.com/forums/showt...5&pagenumber=3
check that thread out - rich gives a good run down
you want a shorter peakier powerband with a m6 than i would want using 3 gears of the A4. I need braoder power band, thats why i opted for a 110 or 112 over a 108... i think i'm going 224/230 on a 112 with some nice lift
Old Jun 9, 2003 | 03:57 PM
97WRAITH's Avatar
Trey how high can I rev with that cam and would my vac decrease to a point where I would have bad braking?
Old Jun 9, 2003 | 06:52 PM
treyZ28's Avatar
i a 350- i'd guess 6500 at least with good heads. LT4 hot cam guys are revving to 6300 all day... this is a lot bigger than the LT4 hotcam too..
6400 is my guess.
I'm using that cam with rediculious lift (well, for a hydrolic roller) in my 383 and hoping for 6500 -6600 shift points.
Thats if i decide against the turbo project
I'm having a hard time passing up this idea
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
