Cam with 1.7's and stock heads
Old Apr 16, 2006 | 03:07 PM
94Zman's Avatar
Running a 94 auto, thinking of a cam upgrade with my 1.7 roller rockers and a PCM for Less tune, what's produces a good hp and torque increase?
Old Apr 16, 2006 | 09:00 PM
seawolf06's Avatar
Re: Cam with 1.7's and stock heads
You're going to get a lot of opinions on here about cams. Do a search first, you'll find a lot more that way. Second, you really wouldn't want to deal with 1.7 RR with any cam. They change your geometry and not simply a "bolt-on" like some 1.6 RR, which I've been suggested to get the 7/16" stud comp pro mags. Here's some specs for you to browse through, although I think many will agree the rpm ranges aren't quite so accurate.
http://www.z28.com/forum/showthread.php?t=58050
Old Apr 17, 2006 | 08:23 AM
94Zman's Avatar
Old Apr 17, 2006 | 08:41 AM
LameRandomName's Avatar
Originally Posted by 94Zman
...thinking of a cam upgrade with my 1.7 roller rockers...
Don't do that.
If you want to put 1.7's on a stock cam so you don't have to change cams, that's one thing.
But to change the cam AND put a set of 1.7's on it? That's crazy.
Just buy the right cam to begin with and run 1.6's or even 1.5's.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Killer94z
Jan 13, 2015 12:06 PM
birdblack
Dec 30, 2014 06:59 PM
Brian-94TA
Jul 31, 2002 02:52 PM
