1.7 roller rockers
Old Apr 16, 2006 | 11:45 AM
jadams94ta's Avatar
1.7 roller rockers
what do i need to put them on my car. can some one give me the part number for them and where i could get them
thanks
jason
Old Apr 16, 2006 | 12:06 PM
Stoopalini's Avatar
Re: 1.7 roller rockers
If you do a search for 'scorpion' and '1.7' and you'll find quite a bit of info out there.
Here is a thread explaining the whole process with part numbers. Read the whole thing though, as I changed my mind a few times during the process.
http://camaross.com/forums/showthread.php?t=422491
Thomas.
Old Apr 16, 2006 | 03:54 PM
jadams94ta's Avatar
what the hp difference from 1.6 and 1.7
Old Apr 16, 2006 | 04:04 PM
MeanGreen97Z's Avatar
The 1.7 rockers take your stock cam to .510/.521 lift. They change your @50 duration slightly. There is a little power in them. As soon as I get back home from Iraq I am installing them on a set of LE1 heads and getting a nice little tune. We will see how much power it makes.
Old Apr 16, 2006 | 04:08 PM
jadams94ta's Avatar
i dont know which one i want to do yet . what size does the 1.6 make a stock cam
Old Apr 16, 2006 | 04:23 PM
Around .480/.490.... The 1.7s are good if you dont intend on installing a cam in the car. 1.6s are good to keep the future open to a cam.
Old Apr 16, 2006 | 07:41 PM
jadams94ta's Avatar
i dont plain on putting one in this motor cause im plaining on buliding something this winter
Old Apr 17, 2006 | 08:47 AM
If you dont plan on going with a cam afterwards then I would definately go with a set of Scorpion 1.7 RRs. They will require a little modification to the GMPP guideplates and the valve covers but other than that they are good to go. Make sure to check your geometry after install to help choose your pushrods. They should be the last thing you purchase to ensure proper alignment of the rockers over the valves.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
