Cam $$$$
Re: Cam $$$$
Theres enough help around OKC you can install yourself. If not plan on $2k.
Mine:
Used cc306 - $150
new oem push rods - $25
New timing set - $100
New CC612 Springs - $100
Used crane 1.6 - $150
Used low mileage oem lifters - $30
gaskets/fluid etc - $50
So total of around $600. It can be done cheap.
Mine:
Used cc306 - $150
Re: Cam $$$$
I think mine ran me about $1000 for all of the parts, but they were all new
cam 218/230 $225
ISKY springs $80.96
GM guide plates $ 18.00
Hardened pushrods $33.26
Pro Mag 1.6 RR's $245
GM valve stem seals $24
Titanium reatainers $135
GM cam gasket set $84
Spring seats $42
LT4 timing chain ~$200
ARP bolts ~$60
cam 218/230 $225
ISKY springs $80.96
Spring seats $42
ARP bolts ~$60
Re: Cam $$$$
i have a LT4 Hot Cam Kit for sale. It has the cam,spring retainers, rocker arms, and hardened push rods. $400 them cam kit has under 1500 miles. The only thing i would upgrade would be the timing chain, which i do not have for you but..... email me if intrested
Re: Cam $$$$
Here's mine:
Used Hotcam: $100
New OEM lifters/retainers: $230
Cam swap gasket kit (Thunder Racing): $80
New OEM timing set: $100
Comp Cams 1.6 RR's: $270
LT4 spring kit: $65
OEM pushrods: $25
Valve stem seals: $20
Fuel injector o-rings: $6.00
ARP rocker stud bolts: $20
Thread lock, RTV's, Coolant, and Oil/filter: ~$50
Used Hotcam: $100
LT4 spring kit: $65
OEM pushrods: $25
