Callies Stealth Crank hub bolt size?
Old Dec 29, 2009 | 05:19 PM
MikeGyver's Avatar
The factory LT1 hub bolt feels like its trying to make it's own threads, does anyone know what thread size and pitch it is?
Old Dec 29, 2009 | 05:49 PM
Bersaglieri's Avatar
That doesn't sound good
-Dustin-
Old Dec 29, 2009 | 09:32 PM
MikeGyver's Avatar
Did those of you with aftermarket cranks use the factory 7/16" x 20tpi bolt?
Old Dec 29, 2009 | 09:55 PM
Are the threads on your bolt in good shape?
Old Dec 30, 2009 | 12:34 AM
MikeGyver's Avatar
Yes, they look fine. A buddy suggested that the bolt may have stretched, although it threads into the factory crank just fine.
7/16x20 appears to be a standard pitch on (almost?) all SBC applications. I'm going to buy a new bolt and see if it threads in ok.
Old Dec 30, 2009 | 06:06 PM
Is it a problem with length? I have the Callies Stealth, and I VAGUELY remember an issue with the length of the bolt... but that was almost 10 years ago, and the shop that built the engine solved the problem while I was working in Italy.
Old Dec 30, 2009 | 07:59 PM
MikeGyver's Avatar
The threads don't start until 1 inch deeper, so I need an inch longer bolt.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
cyteone
Feb 7, 2015 06:04 PM
