CAI which makes the most HP ?
Old Dec 12, 2003 | 12:02 PM
T/A#4's Avatar
Anyone read any dyno test or track tets on different units ?
Thanx in advance ..
Old Dec 12, 2003 | 12:15 PM
Tair's Avatar
I don't believe there are dyno tests to prove gains over other CAI's. Just look for one that uses a conical filter at the end. (K&N FIPK, Moroso, Lingenfelter) Should cost you around $200 no matter what brand you go with, and installation yourself is extremely easy.
Old Dec 12, 2003 | 12:25 PM
drewstealth's Avatar
The difference between the different CAI's is not noticable enough to matter. Except for the G2 CAI. Its not really even a CAI. But all the others k&n, moroso, Linginfelter, and SLP, they are all the same. They just very on the way they look. So if you gonna get a used one get the one out of those you can find the best deal on. If your gonna get a new one then get the one that you think looks the best.
I chose the SLP because imo it looks the best out of the others.
Old Dec 12, 2003 | 01:22 PM
stereomandan's Avatar
I like the K&N FIPK because the ducting is plastic which will not heat soak like a metal CAI will. I noticed a difference with mine.(I had driven the car in stock form for 3 years before adding the FIPK, so my butt dyno was pretty tuned) It had a little better throttle response and it seemed to do better on the top end.
Dan
Old Dec 12, 2003 | 01:26 PM
96z's Avatar
96z
They are all equal buy the one that looks best to you and fits your budget.
Old Dec 13, 2003 | 02:43 AM
Eliminator's Avatar
I bought the SLP cause of the look. I also painted it deep cherry red as seen on my web page. I didnt like the factory black paint.
Old Dec 13, 2003 | 02:46 AM
93formula's Avatar
i like the moroso cause its easy to work with, you can remove the cai from the engine bay without going under and removing the air filter.
Old Dec 13, 2003 | 09:55 PM
Eliminator's Avatar
I have to agree putting those filters on sucked!!!
97ChameleonTA
Jun 4, 2015 08:19 AM
alex5366
Feb 17, 2015 09:07 AM
ModdedNerd
Feb 5, 2015 04:37 AM
Cam's maro
Jan 30, 2015 09:21 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
