C230 wiring?
Old Jul 8, 2011 | 11:39 PM
henryz28's Avatar
C230 wiring?
I am having a problem with my 1997 trans am. First off it is a 97 m6 car, but I am using a 96 lt1 and a4 with a 96 a4 engine and trans harness. My main problem is my oil pressure is reading way past 80 and I can not read the SES light with a scanner; the scanner is not even coming on when it is plugged in. I am thinking the c230 plug inside the car is the problem, particularly pin g;Power feed from engine senor Fuse #10. It is not connected to anything inside the car, the c230 plug inside the car has no wire in pin g. I have no idea where I need to splice the pink wire from the engine harness into the body harness. Any one have a interior wiring diagram for a 1997 trans am; i found a bunch on the engine and trans harness but none on the interior harness.
Old Jul 9, 2011 | 07:52 AM
Guest47904's Avatar
Guest
Re: C230 wiring?
C230 pin G goes to the brake switch pin C. Comes out of the switch on pin D to C230 pin H on a Lt Blu/ Blk wire.
That circuit was not used with a manual tranny.
Old Jul 9, 2011 | 01:14 PM
henryz28's Avatar
Re: C230 wiring?
So all it was for on the a4 car was to power the brake switch?
Old Jul 9, 2011 | 01:53 PM
Guest47904's Avatar
Guest
Re: C230 wiring?
It eventually ends up at the PCM for Brake Switch Signal. Maybe for among other things to cut off the cruise control.
Old Jul 9, 2011 | 02:42 PM
Re: C230 wiring?
I thought I recently answered this question on some board somewhere...
Maybe is was one just like it.
Old Jul 9, 2011 | 08:20 PM
henryz28's Avatar
Re: C230 wiring?
Thanks guys I figured it out I had a bad connector at the oil sensor and no power was getting to the orange wire where you reed the codes from. So I installed a new connector and put 12v switched power to the orange wire and I now can read my oil pressure and SES light.
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
