A/C Pully
Old Oct 27, 2003 | 09:55 AM
americanmusscle's Avatar
A/C Pully
My A/C pully is giving out and I asked a mechanic what involves changing it. He told me if its just the pully then thats it but it can also be the entire a/c system with the compresor that is going bad. I really dont understand what the hell he means by that I thought if the bearings went out then you just change the pully not the whole system . Can someone clue me in on this
Old Oct 27, 2003 | 11:28 AM
N E 1?
Old Oct 27, 2003 | 11:36 AM
jonaddis84's Avatar
Not sure on what hes telling you, I know you can usually just replace the clutch, as long as the A/C is not on when it is making the noise it is just the clutch, since it is not spinning anything inside the compressor when the A/C is off.
You could just delete the A/C, that would be the cost effective, weight loss, and clear up the bay a bit, check out the sig.
Old Oct 27, 2003 | 01:13 PM
Any one know how much a new a/c clutch would cost??
magman
Apr 15, 2016 03:08 AM
WPHIG2
Aug 27, 2015 06:37 AM
MikeWhitener
Aug 2, 2015 06:17 PM
colts0455
Jul 7, 2015 07:19 PM
timmy39120
May 8, 2015 11:41 AM
