a/c problem?
Old Mar 21, 2003 | 11:20 PM
ram air camaro's Avatar
a/c problem?
hopfully some of you could relate to my problem and give me some advice on how to solve it, alright guys my a/c is not coming out of the vent holes were they are supposed too. the air is comig out of the bottom and a little from the top, i also noticed something weird, air is also coming out of the firewall where the a/c hose goes inside the car. i think i need some part that will cover the gap where the a/c hose enters the car through the firewall, i tried searching but couldnt find some one that had this problem. any help is needed to solve this problem! thanx
Old Mar 21, 2003 | 11:30 PM
Your vent problem is likely a vacuum leak in a hose for the mode controls. When there is not enough vacuum, the air will default to coming out only the floor and the defrost vents.
Here is some stuff I already have written up:
An easy way to tell what part of the system may have trouble is to go to the vacuum check valve and test the lines back to the mode selector and to the vacuum canister. If you have a hand held vacuum pump, it would be pretty easy. What you would want to do is remove the hoses one at a time and apply vacuum to each and see if it holds. The line to the intake manifold will have to be removed at the manifold and plugged back toward the check valve for you to test the line for leaks. You can test the check valve, too. Sometimes they are the cause of a leak.
If you find a leak on a particular hose, you will have to trace out the cause on that section.
Old Mar 22, 2003 | 12:55 AM
i've replaced that vacumm valve before but not too sure if installed correctly didnt even know it was that.
Old Mar 22, 2003 | 01:05 AM
do you think if i put it backwards that would be the cause ? i'll check it tommorrow morning. thanks for that info i'll tell you what happens
Old Mar 24, 2003 | 10:22 PM
problem fixed! it was the pcv vacum valve broken, thanks for the help shoebox.
HectorM52
Jun 23, 2016 08:42 PM
HarleyZ28
Oct 5, 2015 06:23 AM
alphaauto
Feb 5, 2015 05:25 PM
Duke
Sep 3, 2002 02:48 PM
IROC5.7TPI
Aug 13, 2002 01:29 PM
