A/C Delete pully?
Old May 7, 2007 | 01:24 PM
  #16
jasonisdn's Avatar
thats a damn good price, is it a oem part or a *** part?
Old May 7, 2007 | 02:35 PM
  #17
IrocSS85's Avatar
the rad. DOES hold itself in as suggested already. the a/c condensor attaches to the radiator, and the rad. does all the holding in place. no problem there. but, I bought a GM delete pulley and I had to get a shorter belt. dont remember what size belt though. sorry. if I get the car up in the air again soon, I'll get the gatorback part # off it for you.
Old May 7, 2007 | 03:15 PM
  #18
The Engineer's Avatar
On the condenser removal issue, it has been awhile since I had the radiator out and couldn’t remember exactly which part supported the other. But I do remember they were sand witched together.
Also, if you just remove the condenser you will have a minor air ducting leak issue (gaps on each side of the radiator) the thickness of the condenser. Did the F-Bodies w/o factory A/C have different plastic ducting that would eliminate the gaps?
WD
Old May 7, 2007 | 05:07 PM
  #19
tim95z28's Avatar
Probably chinese, but who knows where the oem part comes from?
Old May 7, 2007 | 06:02 PM
  #20
jasonisdn's Avatar
canada, its on the back of it
Old May 7, 2007 | 06:39 PM
  #21
neversummer's Avatar
I bought mine from Autozone. It was about $40. It could have been better. I think i replaced the included "bearing" and bolt. I put my alternator where the AC was and put the new pulley where the alternator was. Had to use a 3 inch shorter belt.
I saw no problems without running the condenser. The radiator sat down on the rubber down low and the plastic piece with emmisions info holds the radiator in fine.
Old May 7, 2007 | 06:52 PM
  #22
IrocSS85's Avatar
as for the radiator air leak, yes, it wouldnt be as sealed as factory. but unless your roadracing, shouldnt ever be an issue. the added air flow through the rad. because the condensor isnt there will outweigh the air that gets around the rad. now that the condensor is gone. dont know if those 1LE cars had diff. ducting plastics though. you could prolly make something up relitivly easy though and rivet it to the existing ducting.
Old May 7, 2007 | 08:15 PM
  #23
BlackScreaminMachine's Avatar
I used sam taylor. they are great and similar price to GMpartsdirect and quicker!
Old May 8, 2007 | 02:19 AM
  #24
derbs's Avatar
I didnt know I need to do that much with it. Man
Old May 10, 2007 | 05:58 PM
  #25
flyinZ's Avatar
Could anybody show me some pics, of where I bolt the delete pulley??, and where do I bolt the alternator on to? what bolt do I use, and how to run the belt?? thanks!
Old May 10, 2007 | 06:49 PM
  #26
IrocSS85's Avatar
first you have to remove the a/c compressor. thats almost all of the work. the delete pulley will bolt in place of the compressor with three bolts. very easy to do (after you have the compressor off. not so easy to do. but anyone CAN do it with patience. nothing else to do except make sure your serp belt fits. some people reused the stock belt looks like. mine def. needed a custom length. shorter then stock. but I also have an underdrive pulley on the crank, so my length prolly wouldnt be right for you. I'll try to get it up in the air tomorrow night and take some pics for you.
Old May 12, 2007 | 04:27 PM
  #27
flyinZ's Avatar
If this bolts in place, of your compressor, then what happens to your alternator? I thought this was suppose to relocate your alternator?
Old May 12, 2007 | 05:00 PM
  #28
ChevyTuffD.A.'s Avatar
The alternator does not move, the only thing you are messing with is the compressor.
Old May 12, 2007 | 05:41 PM
  #29
IrocSS85's Avatar
yeah, there are alt. relocator kits that move the alt. down in place of the a/c, and the delete pulley goes up high in place of the alt. orig. location. but were talking about just a normal, a/c delete pulley.
Old May 12, 2007 | 06:01 PM
  #30
flyinZ's Avatar
Gotcha..You wouldn't know, if there is a part # for the alternator relocator kit would ya? Thats what I originally wanted to do. Doh!
magman
Apr 15, 2016 03:08 AM
WPHIG2
Aug 27, 2015 06:37 AM
tnmotown
Aug 10, 2015 11:52 PM
MikeWhitener
Aug 2, 2015 06:17 PM
colts0455
Jul 7, 2015 07:19 PM
