A / C delete?
Old Apr 16, 2012 | 03:27 PM
timelord's Avatar
A / C delete?
Is there a shorter acc belt to bypass the A / C without needing a a/c replacing pulley.
Old Apr 16, 2012 | 03:42 PM
Dave89IROC's Avatar
Lt1 engine? No, get the pulley, use the same belt
Sent from my PC36100 using Tapatalk 2
Old Apr 16, 2012 | 03:57 PM
timelord's Avatar
Re: A / C delete?
Thank you for the quick response.
Old Apr 16, 2012 | 05:21 PM
greenformula94's Avatar
Re: A / C delete?
yep otherwise if you try and run a shorter belet without that pulley, some of your accesories will run the wrong direction.
Old Apr 16, 2012 | 08:05 PM
timelord's Avatar
Re: A / C delete?
Had never thought of that ,thanks!!!!!
Old Apr 17, 2012 | 02:10 AM
rat's nest Z-28's Avatar
Re: A / C delete?
I bought the A/C delete bracket w/pulley & I needed to but a shorter belt...
Old Apr 17, 2012 | 10:51 AM
Dave89IROC's Avatar
You buy the ac delco one?
Old Apr 17, 2012 | 11:11 AM
Re: A / C delete?
You should not need a shorter belt. Hell I even had the cheap one off ebay and it used the stock belt.
Old Apr 17, 2012 | 08:52 PM
SupersportLS1's Avatar
Re: A / C delete?
I had to get a shorter belt for mine. The only gain is weight loss. Im putting my a/c back on its only restricting when its on.
Old Apr 19, 2012 | 10:09 PM
Matts97camaro's Avatar
Re: A / C delete?
I run the AC delete pulley and had to get a shorter belt.
Old Sep 9, 2012 | 08:37 PM
8bud's Avatar
Re: A / C delete?
It looks like I need a shorter belt for my delete pulley also. I have the GM pulley and the belt is so loose it doesnt even stay on. Any of you guys have a part number for the belt I need by any chance?
Old Sep 9, 2012 | 09:14 PM
Re: A / C delete?
I believe there may have been two different A/C clutch pulley diameters used, and whether you need a new belt when you use the A/C delete pulley will depend on which diameter clutch pulley you had.
Old Sep 9, 2012 | 11:37 PM
Re: A / C delete?
Exactly. There were two different diameter a/c pulleys used. Use a 642 belt for the bigger pulley or a 637 [edit: should be 635] for the smaller one.
Old Sep 10, 2012 | 08:09 AM
8bud's Avatar
Re: A / C delete?
Thanks for the info. I definitely ended up with a smaller delete pulley than the size my compressor pulley was. Is 637 the ac delco part number?
Old Sep 11, 2012 | 05:12 AM
Re: A / C delete?
The A/C delete pulley is a smaller diameter, but it's offset on the bracket to hold the belt length.
