A/C compressor whine?
Old Jul 13, 2008 | 12:03 AM
klep2024's Avatar
I have a new whine happening ever since i turned my defrost on the other day. Its a lower pitched whine then say if the power steering pump was going out. Could this be a bad or seized a/c compressor? Or possibly a bad a/c clutch? It whines at all rpm and at idle, but when i turn on the defrost or the a/c it goes away.
I've been thinking about just replacing it with an a/c delete pulley anyway. Is there anything else that needs to be done? Or is it just pull the a/c compressor and replace with the pulley? Any help is greatly appreciated!
Old Jul 13, 2008 | 03:51 AM
SS RRR's Avatar
You can take the belt off and spin the a/c pully to see if it makes any noise or if you feel resistence. If it were siezed it make make all kinds of racket. How many miles on it? Mine started making noise around 115K.
Old Jul 13, 2008 | 12:20 PM
klep2024's Avatar
It has 61,000 original miles on it. I just bought the car about two months ago and am only the second owner. Is the black forward most part supposed to spin as well? If it is then mine is seized.
Old Jul 13, 2008 | 08:11 PM
SS RRR's Avatar
No. That is part of the compressor and only spins once the clutches engage.
magman
Apr 15, 2016 03:08 AM
War Engine
Sep 18, 2015 07:28 PM
cristian1311
Sep 12, 2015 08:16 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
WPHIG2
Aug 27, 2015 06:37 AM
