Buying stall converter, what RPM range does the LT4 Hot Cam operate in?
Old Apr 16, 2004 | 12:21 PM
razeak1's Avatar
Thanks for the answers.
Old Apr 16, 2004 | 12:26 PM
razeak1's Avatar
Ooops
Old Apr 16, 2004 | 01:17 PM
krispy's Avatar
from what ive read id vote for a stall btw 3600-4400 if you are looking to get right into the meat of the powerband
Old Apr 16, 2004 | 01:23 PM
screamin94Z's Avatar
yeesh, if you want a mild converter for mostly street action, i wouldnt go over 3400 or so. if your car is intended for strip duty, go ahead and go higher but the hotcam isnt that big compared to a lot of other cams out there, i'd stay with a 3200 or 3400.
Old Apr 16, 2004 | 01:52 PM
Cmr0z28's Avatar
3000....
Old Apr 16, 2004 | 02:02 PM
19camaro71's Avatar
The stock computer can handle up to 3400 stahl, then it requires reprogramming, otherwise the computer will pull horseporwer because it will assume the trans is slipping. It all depends on what your driving coditions will be, if you want to race it, or drive it around town. Good luck!
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
marine1bird
10
Jan 25, 2015 12:02 AM
Red_94Formula
Jan 22, 2015 12:17 AM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
