Buying pistons should I go bigger?
Old Jan 25, 2009 | 03:43 PM
BLWNLT1's Avatar
Ok so here's the deal. I didn't want to take any chances so I sold the SRP pistons I had (to many horror stories)... which were 4.030. But since I had the block worked for the the bore sizes varied from 4.029 - 4.032(3). Now I am going to purchase some diamond pistons (-24cc) but I see a set of the .030 and one that is .040 which should I get. I not know if it would be a risk getting the 4.030 pistons because I do not know how bad there piston sizes vary. WHAT SHOULD I DO?
Old Jan 26, 2009 | 08:50 AM
BLWNLT1's Avatar
anyone?
Old Jan 26, 2009 | 09:01 AM
WS Sick's Avatar
If youre bore clearance only varies a few thousands then a .030 over piston will work. If the pistons measure inconsistant mix and match your set to go with your tighter or looser bores.
Old Jan 26, 2009 | 09:09 AM
cnorton's Avatar
Quality pistons will vary no more than .001 (or less) across a set of eight. My CP pistons are virtually indistinguishable from one another when measured 3/4" from the tip of the skirt. You won't know until you measure the Diamond pistons at the skirt and factor in the recommended piston-to-wall clearance. You might wish to contact Diamond and ask them if their +.030 piston will work in a +.032 bore.
Old Jan 26, 2009 | 09:12 AM
mdacton's Avatar
check the bore with a tq plate on it.
normally you don't finsh the bore until you have the pistons in your hand....
Old Jan 26, 2009 | 10:09 AM
BLWNLT1's Avatar
they were finished to srp pistons. I will contact diamond to see what they think. I really don't want to go bigger. But will it i have too.
Old Jan 27, 2009 | 04:08 PM
WS Sick's Avatar
Realize also that the piston will expand when it gets hot. See what the clearance window there is.
R@mpage
Apr 20, 2015 10:02 AM
thenewkid
Apr 12, 2015 07:42 PM
carl.froehlich
Mar 13, 2015 12:38 AM
1963SS
Feb 6, 2015 10:05 AM
